hola necesito ayuda urgente:
He instalado un programa para crear paginas de links en mi pagina web. Lo he configurado, pero me da error en esto:
Could not create or append to rl_DATApending.php . Your system needs to be able to read and write to files in this directory
en el archivo de readme, ya avisa de que esto pueda pasar
/* Depdending on your ISP's PHP configuration, the following four files may need */
// to have write permissions set for everyone.
/* mode(0766) rwxrw-rw set for RL system to function. See documentation */
$szLinkIncFile=\"rl_DATAapproved.php\";
$szPendingLinks=\"rl_DATApending.php\";
$szBlockedSites=\"rl_DATAblocked.php\";
$szAppHis=\"rl_DATAhistory.php\";
/****** FILE PERMISSION NOTES **********************************************************/
/* Read this section if Ask and Receive has problems writing to files after it is installed */
/* Depending on how your web server is set up (whether or not your php scripts can run the chmod() function) */
/* you may need to change the permissions on four data files (listed above) to allow */
/* them to have write permission: rwxrw-rw- */
/* If you want to be able to modify this file (rl_DATAvars.php) through the Admininstration utility, you may */
/* also need to change this file's access permissions. */
/* With most ftp clients, this is very simple, and you will need to set the file permissions to: */
/* Read Write Execute Read Write -- Read Write -- rwxrw-rw- chmod(0766) */
/* END of rl_DATAvars.php
Bien, como se arregla esto, alguien tan amable que me pueda explicar un poquito, pues estoy perdida ¿como cambio la configuracion esta?
Gracias la direccion de la página es www.agreatplace.net
