Hola:Tengo problemas de grabación con Nero 7.Me falla muchos discos(cd/dvd)y no se si es problema del software o de la grabadora(LG HL-DT-ST DVDRAM GSA-4160B).Adjunto el informe de error que me da.
Gracias.
REBECCA
4C80909080240000547363230986
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Archivos de programa\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 12:54:32
NT-SPTI used
Nero Version: 7.2.3.2
Internal Version: 7, 2, 3, 2
(Nero Express)
Recorder: <HL-DT-ST DVDRAM GSA-4160B>Version: A306 - HA 1 TA 0 - 7.2.3.2
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <QO5510K WQJ400J >Version: 1.0 - HA 1 TA 2 - 7.2.3.2
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
CdRomPeripheral : Image Simulation 1.0g PrecSim Port 0 ID 0 DMA: Off
DiskPeripheral : ST380011A atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVDRAM GSA-4160B atapi Port 2 ID 0 DMA: On
CdRomPeripheral : QO5510K WQJ400J 1.0 ayg7e2vi Port 4 ID 0 DMA: Off
CdRomPeripheral : QO5510K WQJ400J 1.0 ayg7e2vi Port 4 ID 1 DMA: Off
CdRomPeripheral : TM4228X YGK220T 2.0B asi3v5d9 Port 5 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-4160B D: CDRom0
QO5510K WQJ400J E: CDRom2
Image Simulation F: CDRom1
QO5510K WQJ400J G: CDRom3
TM4228X YGK220T H: CDRom4
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
BUFE : 0
Physical memory : 511MB (523804kB)
Free physical memory: 229MB (234612kB)
Memory in use : 55 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
13.2.2007
CD de audio
20:51:26 #1 CDADOC -1 File Cdadoc.cpp, Line 1601
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 04:24.12, Pause frames: 150, Filters: 0, Name: '1 - Batuka Power - Respira - www.MP3-Es.com.mp3'.
Track 02: Length: 03:49.24, Pause frames: 150, Filters: 0, Name: '2 - Batuka Power - Bendita - www.MP3-Es.com.mp3'.
Track 03: Length: 04:41.18, Pause frames: 150, Filters: 0, Name: '3 - Batuka Power - vive la calle - www.MP3-Es.com.mp3'.
Track 04: Length: 03:18.21, Pause frames: 150, Filters: 0, Name: '4 - Batuka Power -Crucificao- www.MP3-Es.com.mp3'.
Track 05: Length: 03:38.09, Pause frames: 150, Filters: 0, Name: '5 - Batuka Power - Chico bombon - www.MP3-Es.com.mp3'.
Track 06: Length: 03:52.21, Pause frames: 150, Filters: 0, Name: '6 - Batuka Power - Seduccion - www.MP3-Es.com.mp3'.
Track 07: Length: 03:27.54, Pause frames: 150, Filters: 0, Name: '7 - Batuka Power - Aire - www.MP3-Es.com.mp3'.
Track 08: Length: 04:09.27, Pause frames: 150, Filters: 0, Name: '8 - Batuka Power - Tremendo Q - www.MP3-Es.com.mp3'.
Track 09: Length: 03:21.66, Pause frames: 150, Filters: 0, Name: '9 - Batuka Power - Batuka power - www.MP3-Es.com.mp3'.
Track 10: Length: 06:12.69, Pause frames: 150, Filters: 0, Name: '10 - Batuka Power - Guittar rhapsody - www.MP3-Es.com.mp3'.
Track 11: Length: 03:44.00, Pause frames: 150, Filters: 0, Name: '11 - Batuka Power - Haciendo trampas - www.MP3-Es.com.mp3'.
Track 12: Length: 05:13.22, Pause frames: 150, Filters: 0, Name: '12 - Batuka Power - Sounds of peace - www.MP3-Es.com.mp3'.
Total size: 50:16.43
20:51:26 #2 Text 0 File Burncd.cpp, Line 3086
Protección contra insuf. datos activado
20:51:26 #3 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 72704KB of Memory
20:51:26 #4 Text 0 File Reader.cpp, Line 124
Reader running
20:51:26 #5 Text 0 File Writer.cpp, Line 113
Writer D: HL-DT-ST DVDRAM GSA-4160B running
20:51:26 #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
20:51:26 #7 Text 0 File Burncd.cpp, Line 3400
Turn on Disc-At-Once, using CD-R/RW media
20:51:26 #8 Text 0 File DlgWaitCD.cpp, Line 289
Last possible write address on media: 359844 ( 79:59.69)
Last address to be written: 226092 ( 50:16.42)
20:51:26 #9 Text 0 File DlgWaitCD.cpp, Line 301
Write in overburning mode: NO (enabled: CD)
20:51:26 #10 Text 0 File DlgWaitCD.cpp, Line 2715
Recorder: HL-DT-ST DVDRAM GSA-4160B
20:51:26 #11 Text 0 File DlgWaitCD.cpp, Line 473
>>> Protocol of DlgWaitCD activities: <<<
20:51:26 #12 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (1 - Batuka Power - Respira - www.MP3-Es.com.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 19812 (19812) = #19812/4:24.12
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19812 blocks [D: HL-DT-ST DVDRAM GSA-4160B]
1: TRM_AUDIO_NOPRE (2 - Batuka Power - Bendita - www.MP3-Es.com.mp3)
original disc pos #0 + 17199 (17199) = #17199/3:49.24
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17199 blocks [D: HL-DT-ST DVDRAM GSA-4160B]
2: TRM_AUDIO_NOPRE (3 - Batuka Power - vive la calle - www.MP3-Es.com.mp3)
original disc pos #0 + 21093 (21093) = #21093/4:41.18
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21093 blocks [D: HL-DT-ST DVDRAM GSA-4160B]
3: TRM_AUDIO_NOPRE (4 - Batuka Power -Crucificao- www.MP3-Es.com.mp3)
original disc pos #0 + 14871 (14871) = #14871/3:18.21
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14871 blocks [D: HL-DT-ST DVDRAM GSA-4160B]
4: TRM_AUDIO_NOPRE (5 - Batuka Power - Chico bombon - www.MP3-Es.com.mp3)
original disc pos #0 + 16359 (16359) = #16359/3:38.9
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16359 blocks [D: HL-DT-ST DVDRAM GSA-4160B]
5: TRM_AUDIO_NOPRE (6 - Batuka Power - Seduccion - www.MP3-Es.com.mp3)
original disc pos #0 + 17421 (17421) = #17421/3:52.21
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17421 blocks [D: HL-DT-ST DVDRAM GSA-4160B]
6: TRM_AUDIO_NOPRE (7 - Batuka Power - Aire - www.MP3-Es.com.mp3)
original disc pos #0 + 15579 (15579) = #15579/3:27.54
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15579 blocks [D: HL-DT-ST DVDRAM GSA-4160B]
7: TRM_AUDIO_NOPRE (8 - Batuka Power - Tremendo Q - www.MP3-Es.com.mp3)
original disc pos #0 + 18702 (18702) = #18702/4:9.27
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18702 blocks [D: HL-DT-ST DVDRAM GSA-4160B]
8: TRM_AUDIO_NOPRE (9 - Batuka Power - Batuka power - www.MP3-Es.com.mp3)
original disc pos #0 + 15141 (15141) = #15141/3:21.66
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15141 blocks [D: HL-DT-ST DVDRAM GSA-4160B]
9: TRM_AUDIO_NOPRE (10 - Batuka Power - Guittar rhapsody - www.MP3-Es.com.mp3)
original disc pos #0 + 27969 (27969) = #27969/6:12.69
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 27969 blocks [D: HL-DT-ST DVDRAM GSA-4160B]
10: TRM_AUDIO_NOPRE (11 - Batuka Power - Haciendo trampas - www.MP3-Es.com.mp3)
original disc pos #0 + 16800 (16800) = #16800/3:44.0
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16800 blocks [D: HL-DT-ST DVDRAM GSA-4160B]
11: TRM_AUDIO_NOPRE (12 - Batuka Power - Sounds of peace - www.MP3-Es.com.mp3)
original disc pos #0 + 23497 (23497) = #23497/5:13.22
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23497 blocks [D: HL-DT-ST DVDRAM GSA-4160B]
20:51:26 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [D: HL-DT-ST DVDRAM GSA-4160B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 12:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 46950624, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 46950624 47303424 87755472, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 87755472 88108272 137719008, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 137719008 138071808 173048400, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 173048400 173401200 211877568, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 211877568 212230368 253204560, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 253204560 253557360 290199168, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 290199168 290551968 334539072, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 334539072 334891872 370503504, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 370503504 370856304 436639392, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 436639392 436992192 476505792, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 476505792 476858592 532123536, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0x00
-150 | 1 | 0 | 0x21 | 0x00
0 | 1 | 1 | 0x21 | 0x00
19812 | 2 | 0 | 0x21 | 0x00
19962 | 2 | 1 | 0x21 | 0x00
37161 | 3 | 0 | 0x21 | 0x00
37311 | 3 | 1 | 0x21 | 0x00
58404 | 4 | 0 | 0x21 | 0x00
58554 | 4 | 1 | 0x21 | 0x00
73425 | 5 | 0 | 0x21 | 0x00
73575 | 5 | 1 | 0x21 | 0x00
89934 | 6 | 0 | 0x21 | 0x00
90084 | 6 | 1 | 0x21 | 0x00
107505 | 7 | 0 | 0x21 | 0x00
107655 | 7 | 1 | 0x21 | 0x00
123234 | 8 | 0 | 0x21 | 0x00
123384 | 8 | 1 | 0x21 | 0x00
142086 | 9 | 0 | 0x21 | 0x00
142236 | 9 | 1 | 0x21 | 0x00
157377 | 10 | 0 | 0x21 | 0x00
157527 | 10 | 1 | 0x21 | 0x00
185496 | 11 | 0 | 0x21 | 0x00
185646 | 11 | 1 | 0x21 | 0x00
202446 | 12 | 0 | 0x21 | 0x00
202596 | 12 | 1 | 0x21 | 0x00
226093 | lead-out | 1 | 0x01 | 0x00
20:51:26 #14 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
20:51:26 #15 Text 0 File SCSIPassThrough.cpp, Line 84
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
20:51:26 #16 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 16x (2.400 KB/s)
20:51:26 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
20:51:26 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #19962
20:51:26 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #37311
20:51:26 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #58554
20:51:26 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #73575
20:51:26 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #90084
20:51:26 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #107655
20:51:26 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #123384
20:51:26 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #142236
20:51:26 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #157527
20:51:26 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #185646
20:51:26 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #202596
20:51:26 #29 Text 0 File MMC.cpp, Line 17399
StartDAO : CD-Text - On
20:51:26 #30 Text 0 File MMC.cpp, Line 22035
Set BUFE: Buffer underrun protection -> ON
20:51:26 #31 Text 0 File MMC.cpp, Line 17629
CueData, Len=208
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 04 1a 0c
21 02 01 00 00 04 1c 0c
21 03 00 00 00 08 11 24
21 03 01 00 00 08 13 24
21 04 00 00 00 0d 00 36
21 04 01 00 00 0d 02 36
21 05 00 00 00 10 15 00
21 05 01 00 00 10 17 00
21 06 00 00 00 14 01 09
21 06 01 00 00 14 03 09
21 07 00 00 00 17 37 1e
21 07 01 00 00 17 39 1e
21 08 00 00 00 1b 19 09
21 08 01 00 00 1b 1b 09
21 09 00 00 00 1f 24 24
21 09 01 00 00 1f 26 24
21 0a 00 00 00 23 00 1b
21 0a 01 00 00 23 02 1b
21 0b 00 00 00 29 0f 15
21 0b 01 00 00 29 11 15
21 0c 00 00 00 2d 01 15
21 0c 01 00 00 2d 03 15
01 aa 01 01 00 32 10 2b
20:53:50 #32 SPTI -1039 File SCSIPassThrough.cpp, Line 291
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1039)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x09
Sense Qual: 0x01
CDB Data: 0x2A 00 00 02 3C 2B 00 00 1B 00 00 00
Sense Area: 0x70 00 04 00 00 00 00 10 34 10 00 80 09 01
Buffer x05fa0000: Len xf810
0xD6 9F 50 FF F9 A6 5A FE 6E B4 D1 FD 03 B9 74 01
0xA0 CB 4D 09 43 D5 2A 0D 33 BD 36 FE CA CF 3B 31
0xF4 D4 72 49 6D C0 77 20 14 BD C1 19 1A BA F8 1D
20:53:50 #33 CDR -1039 File Writer.cpp, Line 302
Focus or tracking error
20:53:50 #34 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
20:53:50 #35 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
20:53:50 #36 SPTI -1039 File SCSIPassThrough.cpp, Line 291
Sense Code: 0x09
Sense Qual: 0x01
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x71 00 04 00 00 00 00 10 34 10 00 80 09 01
20:53:50 #37 CDR -1039 File WriterStatus.cpp, Line 167
20:53:50 #38 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
20:53:50 #39 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 16x (2.400 KB/s)
20:53:50 #40 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
20:53:50 #41 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 26/10/2005 21:12:48 (Prassi/Veritas driver for win 2K)
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-215
, size=96256 bytes, created 03/08/2004 21:59:42 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Gracias.
REBECCA
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
(Nero Express)
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Use Inquiry : 1
13.2.2007
CD de audio
Burn mode: DAO,
CD Text: On,
Reader running
DAO infos:
MCN: ""
Tracks 1 to 12:
DAO layout:
CueData, Len=208
Sense Code: 0x09
Sense Qual: 0x01
Sense Code: 0x09
Sense Qual: 0x01
Existing drivers:
, size=96256 bytes, created 03/08/2004 21:59:42 (Adapter driver for src)Registry Keys:
