Problema con grabadora LG
Colapsar
X
  • Filtrar
  • Tiempo
  • Mostrar
Limpiar Todo
nuevos mensajes
  • Problema con grabadora LG
    Hola:Ultimamente tengo problemas con la grabadora del pc.La grabadora es de LG y se llama "HL-DT-ST DVDRAM GSA-4160B".Me ha dado un informe de errores que pongo a continuación.Agradecería ayuda.GRACIAS
    1A23-0809-9130-2380-5746-6905
    1A41-70C1-M030-2482-5012-8431
    1A42-0809-4030-2329-9503-7413
    1A43-0609-4030-2312-3383-8659
    1A44-0609-9130-2159-2652-6444
    1A45-0609-9030-2448-3213-9734
    1A46-70C1-M010-2526-3804-8791
    1A47-0609-9030-2261-0221-1250
    1A4A-0609-9130-2091-2397-1890
    1A4C-80C1-M030-2400-5364-4495
    1A4E-70C1-M030-2177-1260-3953
    1A4K-90C1-M040-2753-1220-2853
    1A4M-60C1-M080-2116-1504-4469
    4A40-80C1-M050-2200-1340-5954
    5A49-60C1-M020-2313-0112-7338
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.57 (100, size=48128 bytes, created 23/12/1997 2:23:24
    ahead WinASPI: File 'C:\Archivos de programa\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18:35:34
    Nero Version: 6.6.0.16
    Internal Version: 6, 6, 0, 16b
    Recorder: <HL-DT-ST DVDRAM GSA-4160B>Version: A300 - HA 1 TA 0 - 6.6.0.16
    Adapter driver: <atapi> HA 1
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    CD-ROM: <HL-DT-ST DVDRAM GSA-4160B>Version: A300 - HA 1 TA 0 - 6.6.0.16
    === Scsi-Device-Map ===
    DiskPeripheral : ST380011A atapi Port 0 ID 0 DMA: On
    CdRomPeripheral : HL-DT-ST DVDRAM GSA-4160B atapi Port 1 ID 0 DMA: On
    CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 2 ID 0 DMA: Off
    CdRomPeripheral : Generic DVD-ROM 1.0 d346prt Port 3 ID 0 DMA: Off
    === CDRom-Device-Map ===
    HL-DT-ST DVDRAM GSA-4160B D: CDRom0
    AXV CD/DVD-ROM E: CDRom1
    Generic DVD-ROM F: CDRom2
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 74448896 (0) Byte
    ShowDrvBufStat : 0
    BUFE : 0
    Physical memory : 511MB (523804kB)
    Free physical memory: 55MB (56600kB)
    Memory in use : 89 %
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    18.1.2006
    Imagen de CD
    21:12:46 #1 Text 0 File Burncd.cpp, Line 2948
    Protección contra insuf. datos activado
    21:12:46 #2 Text 0 File Reader.cpp, Line 127
    Reader running
    21:12:46 #3 Text 0 File Writer.cpp, Line 122
    Writer HL-DT-ST DVDRAM GSA-4160B running
    21:12:46 #4 IMAGEGEN -10 File ImageGen.cpp, Line 366
    Image was written as DAO.
    DAOI:
    MediaCatalogNumber = ''
    TocType = 0x00
    Finalized = 1
    First/Last Track = 1 / 1
    1: ISRC = ''
    Blocksize = 2048
    TrackMode = 'TRM_DATA_MODE1'
    TrackConfig = 0x00
    First/Last Index = 0 / 1
    Index0FilePos = 0, Index1FilePos = 307200, NextTrackFilePos = 614938624
    CUES:
    0: Ctrl=0x41 Trk= 0 (0x00) Index=00 Start=954437:08.46 ( -150) RecDep=0x00
    1: Ctrl=0x41 Trk= 1 (0x01) Index=00 Start=954437:08.46 ( -150) RecDep=0x00
    2: Ctrl=0x41 Trk= 1 (0x01) Index=01 Start=00:00.00 ( 0) RecDep=0x00
    3: Ctrl=0x41 Trk=110 (0xAA) Index=01 Start=66:41.38 ( 300113) RecDep=0x00
    MTYP: Mediumtype = CD (old format) (0x1)
    Image file name: <C:\Carpetas\Descargas\Simone Ortega 1080 recetas de cocina spanish.nrg>
    21:12:46 #5 Text 0 File Burncd.cpp, Line 3233
    Turn on Disc-At-Once, using CD-R/RW media
    21:12:46 #6 Text 0 File DlgWaitCD.cpp, Line 270
    Last possible write address on media: 359844 ( 79:59.69)
    Last address to be written: 300112 ( 66:43.37)
    21:12:46 #7 Text 0 File DlgWaitCD.cpp, Line 282
    Write in overburning mode: NO (enabled: CD)
    21:12:46 #8 Text 0 File DlgWaitCD.cpp, Line 2483
    Recorder: HL-DT-ST DVDRAM GSA-4160B;
    CDR code: 00 97 15 17; OSJ entry from: Ritek Co.
    ATIP Data:
    Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
    Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
    21:12:46 #9 Text 0 File DlgWaitCD.cpp, Line 448
    >>> Protocol of DlgWaitCD activities: <<<
    21:12:46 #10 Text 0 File ThreadedTransferInterface.cpp, Line 838
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 (1 - CD-ROM Modo 1, ISO 9660)
    2 indices, index0 (150) provided
    original disc pos #0 + 300113 (300113) = #300113/66:41.38
    not relocatable, disc pos for caching/writing not required/not required, no patch infos
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 300113 blocks [HL-DT-ST DVDRAM GSA-4160B]
    21:12:46 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1051
    Prepare recorder [HL-DT-ST DVDRAM GSA-4160B] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 614938624, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
    -150 | lead-in | 0 | 0x41 | 0x00
    -150 | 1 | 0 | 0x41 | 0x00
    0 | 1 | 1 | 0x41 | 0x00
    300113 | lead-out | 1 | 0x41 | 0x00
    21:12:47 #12 Phase 24 File dlgbrnst.cpp, Line 1832
    Caching of files started
    21:12:47 #13 Text 0 File Burncd.cpp, Line 4120
    Cache writing successful.
    21:12:47 #14 Phase 25 File dlgbrnst.cpp, Line 1832
    Caching of files completed
    21:12:47 #15 Phase 36 File dlgbrnst.cpp, Line 1832
    Burn process started at 40x (6.000 KB/s)
    21:12:47 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2654
    Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
    21:12:47 #17 Text 0 File Mmc.cpp, Line 16924
    StartDAO : CD-Text - Off
    21:12:47 #18 Text 0 File Mmc.cpp, Line 21708
    Set BUFE: Buffer underrun protection -> ON
    21:12:47 #19 Text 0 File Mmc.cpp, Line 17211
    CueData, Len=32
    41 00 00 14 00 00 00 00
    41 01 00 10 00 00 00 00
    41 01 01 10 00 00 02 00
    41 aa 01 14 00 42 2b 26
    21:12:57 #20 Text 0 File Cdrdrv.cpp, Line 1286
    21:12:57.546 - HL-DT-ST DVDRAM GSA-4160B\H1 T0 : Queue again later
    2102 #21 SCSI -1039 File Cdrdrv.cpp, Line 1434
    SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x041F0000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x04 (KEY_HARDWARE_ERROR)
    Sense Code: 0x09
    Sense Qual: 0x01
    CDB Data: 0x2A 0x00 0x00 0x02 0x4E 0x00 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x10
    0x34 0x10 0x00 0x80 0x09 0x01
    2102 #22 CDR -1039 File Writer.cpp, Line 311
    Focus or tracking error
    2102 #23 Text 0 File ThreadedTransfer.cpp, Line 228
    all writers idle, stopping conversion
    2103 #24 Text 0 File ThreadedTransfer.cpp, Line 222
    conversion idle, stopping reader
    2103 #25 SCSI -1039 File Cdrdrv.cpp, Line 1180
    Sense Code: 0x09
    Sense Qual: 0x01
    CDB Data: 0x35 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    Sense Data: 0x71 0x00 0x04 0x00 0x00 0x00 0x00 0x10
    2103 #26 CDR -1039 File WriterStatus.cpp, Line 167
    2103 #27 TRANSFER -24 File WriterStatus.cpp, Line 167
    Could not perform end of Disc-at-once
    2103 #28 Phase 38 File dlgbrnst.cpp, Line 1832
    Burn process failed at 40x (6.000 KB/s)
    Existing drivers:
    File 'Drivers\ASPI32.SYS': Ver=4.57 (100, size=23936 bytes, created 23/12/1997 3:02:46
    File 'Drivers\PXHELP20.SYS': Ver=2.02.60a, size=17232 bytes, created 10/11/2005 19:58:58 (Prassi/Veritas driver for win 2K)
    File 'Drivers\InCDfs.SYS': Ver=4, 3, 11, 1, size=99456 bytes, created 03/01/2005 11:33:44 (InCD4 driver for win NT/2K/XP)
    File 'Drivers\InCDpass.SYS': Ver=4, 3, 11, 1, size=28928 bytes, created 03/01/2005 11:33:24 (InCD4 driver for win NT/2K/XP)
    File 'Drivers\InCDrec.SYS': Ver=4, 3, 11, 1, size=8704 bytes, created 03/01/2005 11:33:46 (InCD4 driver for win NT/2K/XP)
    File 'Drivers\atapi.sys': Ver=?.?.?.?, size=95360 bytes, created 03/08/2004 21:59:44 (Adapter driver for rec)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  • #2
    Re: Problema con grabadora LG
    Hola buenas yo por lo que veo tienes instalado el programa ALCOHOL 120% quizas te este dando problemas,de todas formas yo creo que deberias de isntalarte de los controladores aspi, y ademas pensaria en actualizar la firmware de la grabadora.
    MODELO LG 4160B
    FIRMWARE.A300 mira a ver si hay alguna version mas nueva.creo que es la A304.
    Suerte.
    Trabajando...
