Hola a todos,
a ver si alquien me puede ayudar con este problemilla XD
Tengo una STK SL500 (SCSI-LVD) con dos drives 2x HP Ultrium LTO3 conectada a un Servidor de backup con Solaris 9 y Netbackup.
Después de reinicar el servidor de backup ,éste no ve la linrería SL500, ni los drives, el error del archivo f /var/adm/messages
del servidor muestra el siguiente mensaje:
May 19 11:45:32 multivac genunix: [ID 540533 kern.notice] ^MSunOS Release 5.9 Version Generic_118558-13 64-bit
May 19 11:45:32 multivac genunix: [ID 943905 kern.notice] Copyright 1983-2003 Sun Microsystems, Inc. All rights reserved.
May 19 11:45:32 multivac Use is subject to license terms.
May 19 11:46:55 multivac genunix: [ID 408789 kern.warning] WARNING: mpt0: fault detected in device; service unavailable
May 19 11:45:32 multivac genunix: [ID 678236 kern.info] Ethernet address = 0
ba
75:64
May 19 11:46:55 multivac genunix: [ID 451854 kern.warning] WARNING: mpt0: firmware load failed
May 19 11:45:32 multivac unix: [ID 389951 kern.info] mem = 50331648K (0xc00000000)
May 19 11:46:55 multivac scsi: [ID 107833 kern.warning] WARNING: /ssm@0,0/pci@1d,700000/scsi@3 (mpt0):
May 19 11:45:32 multivac unix: [ID 930857 kern.info] avail mem = 49565548544
May 19 11:46:55 multivac attach failed
May 19 11:45:32 multivac rootnex: [ID 466748 kern.info] root nexus = Sun Fire 6800
May 19 11:46:55 multivac mpt: [ID 576234 kern.warning] WARNING: ID[SUNWpd.mpt.attach.4011]
May 19 11:45:32 multivac rootnex: [ID 349649 kern.info] ssm0 at root: SSM Node 0
May 19 11:48:18 multivac genunix: [ID 408789 kern.warning] WARNING: mpt1: fault detected in device; service unavailable
May 19 11:45:32 multivac genunix: [ID 936769 kern.info] ssm0 is /ssm@0,0
May 19 11:48:18 multivac genunix: [ID 451854 kern.warning] WARNING: mpt1: firmware load failed
May 19 11:45:32 multivac ssm: [ID 349649 kern.info] pci108e,80010 at ssm0: Node 0 Safari id 24 0xc700000
May 19 11:48:18 multivac scsi: [ID 107833 kern.warning] WARNING: /ssm@0,0/pci@1d,700000/scsi@3,1 (mpt1):
May 19 11:45:32 multivac genunix: [ID 936769 kern.info] pcisch0 is /ssm@0,0/pci@18,700000
May 19 11:48:18 multivac attach failed
Si alguien me puede ayudar a dilucidar porqué no carga el firmware de los drives se lo agaradecería enormemente,
Muchas gracias por adelantado !!! XDDDD
