Processors Information
Processor 1 (ID = 0)
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name Intel Celeron
Codename Willamette
Specification Intel(R) Celeron(R) CPU 1.70GHz
Package Socket 478 mPGA (platform ID = 2h)
CPUID F.1.3
Extended CPUID F.1
Brand ID 10
Core Stepping E0
Technology 0.18 um
Core Speed 1693.5 MHz (17.0 x 99.6 MHz)
Rated Bus speed 398.5 MHz
Stock frequency 1700 MHz
Instructions sets MMX, SSE, SSE2
L1 Data cache 8 KBytes, 4-way set associative, 64-byte line size
Trace cache 12 Kuops, 8-way set associative
L2 cache 128 KBytes, 4-way set associative, 64-byte line size
FID/VID Control no
Features
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01001005h
Max CPUID level 00000002h
Max CPUID ext. level 80000004h
Function eax ebx ecx edx
0x00000000 0x00000002 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00000F13 0x0001080A 0x00000000 0x3FEBF9FF
0x00000002 0x665B5001 0x00000000 0x00000000 0x00397040
0x80000000 0x80000004 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000000 0x00000000
0x80000002 0x20202020 0x20202020 0x20202020 0x20202020
0x80000003 0x65746E49 0x2952286C 0x6C654320 0x6E6F7265
0x80000004 0x20295228 0x20555043 0x30372E31 0x007A4847
Cache descriptor Level 1 D 8 KB 1 threads
Cache descriptor Level 1 T 12 KB 1 threads
Cache descriptor Level 2 U 128 KB 1 threads
MSR 0x00000017 edx = 0x00080000 eax = 0x00000000
MSR 0x0000002A edx = 0x00000000 eax = 0x00004100
MSR 0x000001A0 edx = 0x00000000 eax = 0x000000E1
Chipset
Northbridge SiS 650 rev. 01
Southbridge SiS LPC Bridge rev. 04
Graphic Interface AGP
AGP Revision 2.0
AGP Transfer Rate 4x
AGP SBA supported, enabled
Memory Type DDR
Memory Size 2048 MBytes
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 6
Bank Cycle Time (tRC) 10
Memory SPD
DIMM #1
General
Memory type DDR
Manufacturer (ID) Kreton Corp. (7F7F7F7F7FE30000)
Size 1024 MBytes
Max bandwidth PC3200 (200 MHz)
Part number 515176106581442000
Serial number AD0A0780
Manufacturing date Week 64/Year 08
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Nominal Voltage 2.50 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 133 166 200
CAS# 2.0 2.5 3.0
RAS# to CAS# delay 2 3 3
RAS# Precharge 2 3 3
TRAS 6 7 8
DIMM #2
General
Memory type DDR
Size 1024 MBytes
Part number 515177106581442032
Serial number F8311212
Manufacturing date Week 21/Year 09
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
Timings table
CAS# 2.0 2.5 3.0
TRAS 6 7 8
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 80 08 07 0D 0B 02 40 00 04 50 70 00 82 08 00 01
10 0E 04 1C 01 02 20 00 60 70 75 70 3C 28 3C 28 80
20 60 60 40 40 00 00 00 00 00 37 46 28 28 50 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 F3
40 7F 7F 7F 7F 7F E3 00 00 00 35 31 35 31 37 36 31
50 30 36 35 38 31 34 34 32 30 30 30 41 00 08 40 AD
60 0A 07 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 4B 31 00 00 00 00 00 32 35 31 31 2D 39 37 31 30
90 30 33 30 35 00 00 00 4B 54 39 37 31 30 30 32 30
A0 36 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Dump Module #2
20 70 70 40 40 00 00 00 00 00 37 41 30 28 50 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 16
40 7F 7F 7F 7F 7F E3 00 00 00 35 31 35 31 37 37 31
50 30 36 35 38 31 34 34 32 30 33 32 41 00 09 15 F8
60 31 12 12 00 00 00 00 00 00 00 00 00 00 00 00 00
80 4B 31 00 00 00 00 00 32 35 31 30 2D 39 38 30 34
90 30 38 30 31 00 00 00 4B 54 39 38 30 34 30 37 30
Monitoring
Mainboard Model M935U (0x143 - 0x29DD0)
LPCIO
Vendor ITE
Model IT8705
Vendor ID 0x90
Chip ID 0x8705
Revision ID 0x2
Config Mode I/O address 0x2E
Dump config mode register space, LDN = 0x4
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 05 02 00 F1 00 00 00 00 00 0F 0F 0F 0F 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 90 02 30 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Hardware monitor
ITE IT87 hardware monitor
Voltage sensor 0 1.66 Volts [0x68] (CPU VCORE)
Voltage sensor 1 1.79 Volts [0x70] (VIN1)
Voltage sensor 2 3.28 Volts [0xCD] (+3.3V)
Voltage sensor 3 5.00 Volts [0xBA] (+5V)
Voltage sensor 4 12.10 Volts [0xBD] (+12V)
Voltage sensor 5 -12.99 Volts [0xCB] (-12V)
Voltage sensor 6 -4.35 Volts [0x44] (-5V)
Voltage sensor 7 5.03 Volts [0xBB] (+5V VCCH)
Voltage sensor 8 3.25 Volts [0xCB] (VBAT)
Temperature sensor 0 29°C (84°F) [0x1D] (TMPIN0)
Temperature sensor 1 50°C (121°F) [0x32] (TMPIN1)
Temperature sensor 2 0°C (32°F) [0x0] (TMPIN2)
Fan sensor 0 2860 RPM [0x3B] (FANIN0)
Dump hardware monitor
LPC Register space, base address = 0x0290
00 19 00 FF 07 00 00 00 00 00 00 00 1B 00 3A FF FF
10 FF FF FF 70 87 00 00 00 00 00 00 00 00 00 00 00
20 67 70 CB B4 C3 CB 3F BA CB 1D 31 00 00 00 00 00
30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF 00 00 2D 00 00 00 00 00 00 00
50 FF 0A 7F 7F 7F 00 00 00 90 5C 04 00 00 00 00 00
60 7F 7F 7F 7F 7F 00 00 00 7F 7F 7F 7F 7F 00 00 00
70 7F 7F 7F 7F 7F 00 00 00 00 00 00 00 00 00 00 00
80 19 00 00 00 00 00 00 00 00 00 00 1B 00 3A FF FF
90 FF FF FF 70 87 00 00 00 00 00 00 00 00 00 00 00
A0 67 70 CB B4 C3 CB 3F BA CB 1D 31 00 00 00 00 00
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF 00 00 2D 00 00 00 00 00 00 00
D0 FF 0A 7F 7F 7F 00 00 00 90 5C 04 00 00 00 00 00
E0 7F 7F 7F 7F 7F 00 00 00 7F 7F 7F 7F 7F 00 00 00
F0 7F 7F 7F 7F 7F 00 00 00 00 00 00 00 00 00 00 00
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1039
Model ID 0x0650
Revision ID 0x01
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x20
Header 0x80
PCI header
Address 0 (memory) 0xE0000000
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
AGP Capability
Offset C0h
Version 2.0
Status enabled
Transfer rate 4x (max 4x)
Queue lenght 3 (max 32)
Dump
00 39 10 50 06 07 00 10 22 01 00 00 06 00 20 80 00
10 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00
50 FE 09 70 8B 03 03 B7 0E 02 25 C0 00 12 D1 32 00
60 6F 6F 40 40 C3 00 17 80 01 08 E0 00 40 02 00 00
70 1F 9F 00 00 02 00 60 00 00 00 00 00 02 00 11 00
80 22 26 30 00 85 00 80 0B 20 0C 00 01 00 00 04 7C
90 00 40 00 00 33 04 00 01 00 16 7D 10 00 00 00 00
A0 C2 D4 33 C2 03 03 01 37 00 50 40 C2 42 09 C0 07
B0 00 00 00 10 00 00 00 47 0B 3B 2B 2B 00 0C 80 00
C0 02 00 20 00 07 02 00 1F 04 03 00 00 00 00 00 00
D0 22 02 33 02 49 FF FF 01 60 60 AA 00 00 81 00 00
PCI to PCI Bridge
bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x1039
Model ID 0x0001
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x40
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
Dump
00 39 10 01 00 07 01 00 00 00 00 04 06 00 40 01 00
10 00 00 00 00 00 00 00 00 00 01 02 00 A0 A0 00 20
20 D0 DF E0 DF A0 CF B0 DF 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCI to ISA Bridge
bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x1039
Model ID 0x0008
Revision ID 0x04
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 39 10 08 00 0F 00 00 02 04 00 01 06 00 00 80 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 92 05 80 0B 0B 00 3D 7D 10 00 00 00 11 30 04 01
50 11 38 02 01 60 0B 20 0B AD 04 12 00 05 05 34 00
60 05 0B 0B 0B FF C1 32 12 09 80 00 46 80 00 02 00
70 00 00 FF FF 00 08 00 0C 00 00 00 80 00 00 00 00
90 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 80 40 00 04 00 5B 4E 00 00 00 00 00 00
F0 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 2 (0x02), function 5 (0x05)
Common header
Vendor ID 0x1039
Model ID 0x5513
Revision ID 0x00
PI 0x80
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x80
Header 0x00
PCI header
Address 4 (port) 0x0000FF00
Subvendor ID 0x1039
Subsystem ID 0x5513
Int. Line 0x00
Int. Pin 0x00
Dump
00 39 10 13 55 05 00 00 02 00 80 01 01 00 80 00 00
20 01 FF 00 00 00 00 00 00 00 00 00 00 39 10 13 55
40 00 00 00 00 00 00 00 00 00 00 06 00 00 00 00 00
50 F2 00 F2 00 2A 96 D5 C0 00 00 00 00 00 00 00 00
60 FB AA FB AA 00 00 00 00 00 00 00 00 00 00 00 00
70 17 21 06 04 00 00 00 00 26 21 06 04 00 00 00 00
Modem
bus 0 (0x00), device 2 (0x02), function 6 (0x06)
Common header
Vendor ID 0x1039
Model ID 0x7013
Revision ID 0xA0
PI 0x00
SubClass 0x03
BaseClass 0x07
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 0 (port) 0x0000D400
Address 1 (port) 0x0000D000
Subvendor ID 0x1039
Subsystem ID 0x7013
Int. Line 0x0B
Int. Pin 0x03
Capabilities
Power Management Capability
Offset 48h
Version 1.1
Dump
00 39 10 13 70 05 01 90 02 A0 00 03 07 00 40 00 00
10 01 D4 00 00 01 D0 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 39 10 13 70
30 00 00 00 00 48 00 00 00 00 00 00 00 0B 03 34 0B
40 02 00 00 00 00 00 00 00 01 00 42 C6 00 00 00 00
F0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Audio device
bus 0 (0x00), device 2 (0x02), function 7 (0x07)
Common header
Vendor ID 0x1039
Model ID 0x7012
Revision ID 0xA0
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 0 (port) 0x0000DC00
Address 1 (port) 0x0000D800
Subvendor ID 0x13F6
Subsystem ID 0x0300
Int. Line 0x0B
Int. Pin 0x03
Capabilities
Offset 48h
Version 1.1
Dump
00 39 10 12 70 05 01 90 02 A0 00 01 04 00 40 00 00
10 01 DC 00 00 01 D8 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 F6 13 00 03
40 04 00 00 00 00 00 00 00 01 00 42 C6 00 00 00 00
USB Controller (OHCI)
bus 0 (0x00), device 3 (0x03), function 0 (0x00)
Common header
Vendor ID 0x1039
Model ID 0x7001
Revision ID 0x0F
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x40
Header 0x80
PCI header
Address 0 (memory) 0xDFFF8000
Subvendor ID 0x1039
Subsystem ID 0x7001
Int. Line 0x05
Int. Pin 0x01
Dump
00 39 10 01 70 07 00 80 02 0F 10 03 0C 08 40 80 00
10 00 80 FF DF 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 39 10 01 70
30 00 00 00 00 00 00 00 00 00 00 00 00 05 01 00 50
40 00 00 00 00 5C AC 01 00 7F 02 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 C2 C9
bus 0 (0x00), device 3 (0x03), function 1 (0x01)
Common header
Vendor ID 0x1039
Model ID 0x7001
Revision ID 0x0F
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xDFFF9000
Subvendor ID 0x1039
Subsystem ID 0x7001
Int. Line 0x0B
Int. Pin 0x02
Dump
00 39 10 01 70 07 00 80 02 0F 10 03 0C 08 40 00 00
10 00 90 FF DF 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0B 02 00 50
bus 0 (0x00), device 3 (0x03), function 2 (0x02)
Common header
Vendor ID 0x1039
Model ID 0x7001
Revision ID 0x0F
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xDFFFA000
Subvendor ID 0x1039
Subsystem ID 0x7001
Int. Line 0x0B
Int. Pin 0x03
Dump
10 00 A0 FF DF 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0B 03 00 50
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 3 (0x03), function 3 (0x03)
Common header
Vendor ID 0x1039
Model ID 0x7002
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xDFFFB000
Subvendor ID 0x1039
Subsystem ID 0x7002
Int. Line 0x0B
Int. Pin 0x04
Capabilities
Offset 50h
Version 1.1
Dump
00 39 10 02 70 06 01 90 02 00 20 03 0C 08 40 00 00
10 00 B0 FF DF 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 39 10 02 70
30 00 00 00 00 50 00 00 00 00 00 00 00 0B 04 00 50
40 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00
50 01 00 C2 C9 00 00 00 00 0A 00 00 21 00 00 00 00
60 20 20 7F 00 00 00 00 00 00 00 00 00 00 00 00 00
70 01 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00
Ethernet Controller
bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x1039
Model ID 0x0900
Revision ID 0x90
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 0 (port) 0x0000CC00
Address 1 (memory) 0xDFFF7000
Subvendor ID 0x1039
Subsystem ID 0x0900
Int. Line 0x0B
Int. Pin 0x01
Capabilities
Offset 40h
Version 1.1
Dump
00 39 10 00 09 07 01 90 02 90 00 00 02 00 40 00 00
10 01 CC 00 00 00 70 FF DF 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 39 10 00 09
30 00 00 FC DF 40 00 00 00 00 00 00 00 0B 01 34 0B
40 01 00 02 FE 00 00 00 00 00 00 00 00 00 00 00 00
50 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
VGA Controller
bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1039
Model ID 0x6325
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xD0000000
Address 1 (memory) 0xDFEE0000
Address 2 (port) 0x0000AC00
Subvendor ID 0x1039
Subsystem ID 0x6325
Int. Line 0x05
Int. Pin 0x01
Capabilities
Offset 40h
Version 1.0
AGP Capability
Offset 50h
Version 2.0
Status enabled
Queue lenght 1 (max 16)
Dump
00 39 10 25 63 03 00 B0 02 00 00 00 03 00 00 00 80
10 08 00 00 D0 00 00 EE DF 01 AC 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 39 10 25 63
30 00 00 00 00 40 00 00 00 00 00 00 00 05 01 00 00
40 01 50 01 06 00 00 00 00 00 00 00 00 00 00 00 00
50 02 00 20 00 07 02 00 0F 04 03 00 1F 00 00 00 00
SMBus Controller
bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
Vendor ID 0x1039
Model ID 0x0016
Revision ID 0x00
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x00000C00
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x02
Dump
00 39 10 16 00 01 00 80 02 00 00 05 0C 00 00 00 00
20 01 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00
40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor American Megatrends Inc.
version 07.00T
date 04/02/01
DMI System Information
manufacturer ECS
product M935U
version 1.0
serial 00000000
UUID 00000000-00000000-00000000-00000000
DMI Baseboard
vendor ECS
model M935U
revision 1.0
serial 00000000
DMI System Enclosure
manufacturer ECS
chassis type Desktop
chassis serial 00000000
DMI Processor
manufacturer Intel
model Intel(R) Pentium(R) 4 Processor
clock speed 1700.0 MHz
FSB speed 100.0 MHz
multiplier 17.0x
DMI Memory Controller
correction 32-bit ECC
Max module size 128 MBytes
DMI Memory Module
designation ROW-0
size 1024 MBytes (double bank)
DMI Memory Module
designation ROW-1
DMI Memory Module
designation ROW-2
DMI Memory Module
designation ROW-3
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
DMI Extension Slot
designation PCI4
type PCI
width 32 bits
DMI Extension Slot
designation PCI5
type PCI
width 32 bits
DMI Extension Slot
designation ISA1
type ISA
width 16 bits
DMI Extension Slot
designation ISA2
type ISA
width 16 bits
DMI Port Connector
designation USB (internal)
designation Def (external)
port type SSA SCSI
connector Mini Centronics
connector DB-25 male
Software
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
DirectX Version 9.0c
Resources
Memory I/O Space, BA=0x00000000E0000000
Port I/O Space, BA=0xFF00
Port I/O Space, BA=0xD400
Port I/O Space, BA=0xD000
Port I/O Space, BA=0xDC00
Port I/O Space, BA=0xD800
Memory I/O Space, BA=0x00000000DFFF8000
Memory I/O Space, BA=0x00000000DFFF9000
Memory I/O Space, BA=0x00000000DFFFA000
Memory I/O Space, BA=0x00000000DFFFB000
Port I/O Space, BA=0xCC00
Memory I/O Space, BA=0x00000000DFFF7000
Memory I/O Space, BA=0x00000000D0000000
Memory I/O Space, BA=0x00000000DFEE0000
Port I/O Space, BA=0xAC00
Port I/O Space, BA=0x808, size=0x4
Port I/O Space, BA=0xC00
Port I/O Space, BA=0x290
Port I/O Space, BA=0x2E
Name Intel Celeron
Codename Willamette
CPUID F.1.3
Extended CPUID F.1
Brand ID 10
Core Stepping E0
Technology 0.18 um
FID/VID Control no
Features
Thread dumps
CPU Thread 0
APIC ID 0
Type 01001005h
Chipset
AGP Revision 2.0
Memory Type DDR
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 6
Memory SPD
DIMM #1
General
Memory type DDR
Size 1024 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
Timings table
CAS# 2.0 2.5 3.0
TRAS 6 7 8
DIMM #2
General
Memory type DDR
Size 1024 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
Timings table
CAS# 2.0 2.5 3.0
TRAS 6 7 8
Dump Module #1
Dump Module #2
Monitoring
LPCIO
Vendor ITE
Model IT8705
Vendor ID 0x90
Chip ID 0x8705
Revision ID 0x2
Hardware monitor
PCI Device List
Host Bridge
Common header
Vendor ID 0x1039
Model ID 0x0650
Revision ID 0x01
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x20
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
AGP Capability
Offset C0h
Version 2.0
Status enabled
Dump
PCI to PCI Bridge
Common header
Vendor ID 0x1039
Model ID 0x0001
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x40
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
Dump
PCI to ISA Bridge
Common header
Vendor ID 0x1039
Model ID 0x0008
Revision ID 0x04
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
IDE Controller
Common header
Vendor ID 0x1039
Model ID 0x5513
Revision ID 0x00
PI 0x80
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x80
Header 0x00
PCI header
Subvendor ID 0x1039
Subsystem ID 0x5513
Int. Line 0x00
Int. Pin 0x00
Dump
Modem
Common header
Vendor ID 0x1039
Model ID 0x7013
Revision ID 0xA0
PI 0x00
SubClass 0x03
BaseClass 0x07
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Subvendor ID 0x1039
Subsystem ID 0x7013
Int. Line 0x0B
Int. Pin 0x03
Capabilities
Offset 48h
Version 1.1
Dump
Audio device
Common header
Vendor ID 0x1039
Model ID 0x7012
Revision ID 0xA0
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Subvendor ID 0x13F6
Subsystem ID 0x0300
Int. Line 0x0B
Int. Pin 0x03
Capabilities
Offset 48h
Version 1.1
Dump
Common header
Vendor ID 0x1039
Model ID 0x7001
Revision ID 0x0F
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x40
Header 0x80
PCI header
Subvendor ID 0x1039
Subsystem ID 0x7001
Int. Line 0x05
Int. Pin 0x01
Dump
Common header
Vendor ID 0x1039
Model ID 0x7001
Revision ID 0x0F
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x40
Header 0x00
PCI header
Subvendor ID 0x1039
Subsystem ID 0x7001
Int. Line 0x0B
Int. Pin 0x02
Dump
Common header
Vendor ID 0x1039
Model ID 0x7001
Revision ID 0x0F
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x40
Header 0x00
PCI header
Subvendor ID 0x1039
Subsystem ID 0x7001
Int. Line 0x0B
Int. Pin 0x03
Dump
Common header
Vendor ID 0x1039
Model ID 0x7002
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x08
Latency 0x40
Header 0x00
PCI header
Subvendor ID 0x1039
Subsystem ID 0x7002
Int. Line 0x0B
Int. Pin 0x04
Capabilities
Offset 50h
Version 1.1
Dump
Ethernet Controller
Common header
Vendor ID 0x1039
Model ID 0x0900
Revision ID 0x90
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Subvendor ID 0x1039
Subsystem ID 0x0900
Int. Line 0x0B
Int. Pin 0x01
Capabilities
Offset 40h
Version 1.1
Dump
VGA Controller
Common header
Vendor ID 0x1039
Model ID 0x6325
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1039
Subsystem ID 0x6325
Int. Line 0x05
Int. Pin 0x01
Capabilities
Offset 40h
Version 1.0
AGP Capability
Offset 50h
Version 2.0
Status enabled
Dump
SMBus Controller
Common header
Vendor ID 0x1039
Model ID 0x0016
Revision ID 0x00
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x02
Dump
DMI
DMI BIOS
version 07.00T
date 04/02/01
manufacturer ECS
product M935U
version 1.0
serial 00000000
DMI Baseboard
vendor ECS
model M935U
revision 1.0
serial 00000000
manufacturer ECS
DMI Processor
manufacturer Intel
FSB speed 100.0 MHz
multiplier 17.0x
DMI Memory Module
designation ROW-0
DMI Memory Module
designation ROW-1
DMI Memory Module
designation ROW-2
DMI Memory Module
designation ROW-3
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
DMI Extension Slot
designation PCI4
type PCI
width 32 bits
DMI Extension Slot
designation PCI5
type PCI
width 32 bits
DMI Extension Slot
designation ISA1
type ISA
width 16 bits
DMI Extension Slot
designation ISA2
type ISA
width 16 bits
DMI Port Connector
port type SSA SCSI
Software
Resources
