Hola, esta placa base lleva 2 ide ata 133 ,puedo instalar dispositivo udma100 ?
ASROCK 775DUAL-VSTA INTEL SOCKET775 AGP/PCI-EXPRES
Fabricado por: ASROCK
Descripción: LGA 775 for Intel® Core? 2 Duo/ Pentium® XE / Pentium® D / Pentium® 4 / Celeron® D, supporting Conroe processors
VIA PT880 Pro/Ultra Chipset
Supports FSB1066/800/533MHz processor, EM64T CPU and H-T Technology
Supports Dual Channel DDRII667 (DDRII x 2 DIMMs) and DDR400 (DDR x 2 DIMMs)
Untied Overclocking : During Overclocking, FSB enjoys better margin due to fixed PCIE/ PCI Buses
1 x PCI Express Graphics slot
1 x AGP 8X slot
Hybrid Booster - Safe Overclocking Technology
2 ports of SerialATA 1.5Gb/s, support RAID 0, 1, JBOD, 2 ATA133 IDE ports
HDMI_SPDIF header, providing SPDIF audio output to HDMI VGA card, allows the system to connect HDMI Digital TV/projector/LCD devices.
7.1 channel with High Definition Audio, 10/100 Ethernet LAN
Windows Vista? Premium Logo Hardware Ready
HD 8CH I/O: 4 ready-to-use USB2.0 ports, HD 7.1 channel audio jacks
Gracias?
y la fuente de alimentacion cuantos pines tiene que tener?
1 x AGP 8X slot
Gracias?
