How does the white screen work?
Colapsar
X
  • Filtrar
  • Tiempo
  • Mostrar
Limpiar Todo
nuevos mensajes
  • How does the white screen work?
    The white screen comes with a simple set of steps. Anyone can use it without any problem or assistance; the tool is made so that it gives a simple and satisfying experience.
    You need to click on the blank white screen or display if you want a white background and click on the given colors.
    • bright red screen
    • light yellow screen
    • light pink screen
    • light purple screen
    • green Screen
    • black Screen
    Steps to be followed:
    Step 1: Open the website, and you’ll land on the home page.
    Step 2: Tap on the image of the white-screened monitor on your screen.
    Step 3: The background, or display image, can be seen turning completely white.
    Step 4: By pressing on the color you need the most, the pixels can be treated, and the dust can be cleaned.
Trabajando...
X
