Buenas!!
Me gustaría ampliar mi PC antiguo cambiando el hardware necesario.. Llevo 3 días exhaustivos buscando hardware, compatibilidades con placa base, chipset, memoria Ram ddr2, ddr3, fuente de alimentación, etc.. y la verdad, que cuanto más navego y más me informo en busca de la elección correcta... más dudas tengo....
Mi PC es el siguiente:
Mainboard Model MS-7502
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Core 2 Quad Q8300
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz
Package (platform ID) Socket 775 LGA (0x4)
CPUID 6.7.A
Extended CPUID 6.17
Core Stepping R0
Technology 45 nm
TDP Limit 95.0 Watts
Core Speed 1994.8 MHz
Multiplier x Bus Speed 6.0 x 332.5 MHz
Rated Bus speed 1329.9 MHz
Stock frequency 2500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 2048 KBytes, 8-way set associative, 64-byte line size
Chipset
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IH (ICH9DH) rev. 02
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 6 GBytes
Channels Dual, (Symmetric)
Memory Frequency 332.5 MHz (1:1)
CAS# latency (CL) 5.0
Memory SPD
DIMM # 1
Memory type DDR2
Module format Regular UDIMM
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number MEU02G64D6BF2EP-2A
Serial number 8600008E
Number of banks 8
Data width 64 bits
DMI Processor
manufacturer Intel
model Intel(R)
clock speed 2500.0 MHz
FSB speed 333.0 MHz
multiplier 7.5x
Display Adapters
Display adapter 0
Name NVIDIA GeForce GTX 750 Ti
Board Manufacturer GIGABYTE Technology
Revision A2
Codename GM107
Technology 28 nm
Memory size 2 GB
Memory type GDDR5
Performance Level 0
Core clock 1058.5 MHz
Memory clock 2700.0 MHz
Software
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1
DirectX Version 11.0
Según mi investigación:
1. Mi placa base solo acepta hasta 8GB RAM, por ese motivo voy a ampliarlo 2GB más, en teoría solo acepta ddr2 ¿ es posible que también pueda aceptar memoria ddr3?.
2. Estoy pensando en cambiar mi fuente de alimentación, ya que la que ahora tengo solo tira 3500W, había pensado en la siguiente: Mars Gaming MPII650, Fuente De Alimentación Para Ordenador, SATA, 650W, Rojo
3. La gráfica que tengo la cambié hace poco, así que no tengo pensado cambiarla a priori.... nunca se sabe...
4. el tema de la CPU había pensado en comprar un procesador: Procesador Intel® Xeon® X5460 caché de 12 M, 3,16 GHz, FSB de 1333 MHz ¿aunque no se si es compatible con mi chipset? ¿lo es? ¿hay otro mejor compatible?
5. Por último, decir, que ya he comprado un disco duro SSD de la marca Crucial MX500 de 500GB para sustituirlo por el que tengo, de esta manera ganaré en velocidad.
Ya sé que mi ordenador es un poco antiguo, pero aún así me rinde bastante bien actualmente, por eso he pensado que con algunos retoques me podría durar unos cuantos años más. Por tanto, en relación con mi hardware... ¿Qué podría cambiar o sustituir para sacarle el mayor rendimiento posible? al máximo según sus posibilidades....
En caso de necesitar más información no dude en pedirlas
Muchas Gracias por adelantado!!!
Processor 1 ID = 0
Codename Yorkfield
CPUID 6.7.A
Extended CPUID 6.17
Core Stepping R0
Technology 45 nm
Chipset
Memory Type DDR2
Memory SPD
DIMM # 1
Memory type DDR2
Size 2048 MBytes
Number of banks 8
Data width 64 bits
DMI Processor
manufacturer Intel
model Intel(R)
FSB speed 333.0 MHz
multiplier 7.5x
Display Adapters
Display adapter 0
Revision A2
Codename GM107
Technology 28 nm
Memory size 2 GB
Memory type GDDR5
Performance Level 0
Software
